Need assistence with motion tracking!
Charlie Wilson
on May 24, 2016 at 7:19:08 pm
I've figured out the basics of it okay and I can easily get text to want. But I have some animated text that I made within Adobe After effects. It's currently in a ore-composition / group. I this to be in the motion tracking but I can figure this out.
If anyone wants to get into skype with me and talk me through it or join my teamspeak and talk me through it that would be great
Other wise I'll try follow instructions left by you in the replies
Michael Szalapski
Re: Need assistence with motion tracking!
on May 24, 2016 at 9:10:33 pm
I don't understand the issue you're having. You can apply tracking data to anything in AE including compositions. I usually apply tracking data to a null object and then parent whatever it is I want to add to the scene to the null.
Unless you're talking about using the camera tracker, in which case, you can simply create a null based off of any tracking point you would like and then set the position of your composition to be in that same spot.
- The Great Szalam
