Merging separate shape paths into one
Jason Brown
on May 20, 2016 at 7:55:00 pm
Okay, I have 2 shape layers made up of individual paths forming the whole. The desired effect is to transform shape 1 into shape 2 by keyframing the shape paths.
However shape 1 has 5 sub shapes and shape 2 has 3 sub shapes.
All is fine when I copy a single shape path from shape 1 and keyframe into a shape path from shape 2, so I go:
copy and paste
path 1 to 1
2 to 2
3 to 3
these all transform fine, but I have 2 leftover shapes.
4 to ?
5 to ?
I've tried copying all the shapes paths (3,4,5) and pasting them into a single shape layer but that doesn't give me a single shape path, they're still individual and the shape doesn't appear it just shows the path outline.
Any help is much appreciated,
Greg Gesch
Re: Merging separate shape paths into one
on May 22, 2016 at 3:58:27 am
Hi. The only thought I have is to duplicate (say) paths 2 and 3 in your final shape layer, then when you want the two missing paths to appear keyframe paths 4 and 5 onto the duplicates - it would mean the peel away from the existing shapes though.
Graham Quince
on May 23, 2016 at 8:57:14 am
Are you copying the keyframed paths or just the paths themselves?
Have you seen Chris Zwar's tutorial on morphing. It might help a little.
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
Jason Brown
on May 23, 2016 at 2:13:31 pm
Thanks for the replies.
I kind of found a fix that worked for me. The 2 left over shape paths I had I just keyframed their position and scale and hid them behind the other shapes, so it appears as 2 shapes morphing into one.
