Horizontal bars sliding transition effects
Shyam Thampi
on May 19, 2016 at 3:05:18 pm
Trying to re create a transition effect used in the Adidas ad below.
https://vimeo.com/134966392
The effect happens at 00:02 and also at 00:55. Face transitioning.
I tried making this effect as a black and white transition in a pre comp and then applying it back to the face with horizontal scaling effects. Not getting it right, though.
Shyam
Michael Szalapski
Re: Horizontal bars sliding transition effects
on May 19, 2016 at 4:37:15 pm
I can't see your example due to restrictions on the network where I work, but from your description, is this what you want?
It was the first result when I did a Google search for Adidas ad After Effects tutorial and it has horizontal bars in the thumbnail
- The Great Szalam
Kevin Camp
on May 20, 2016 at 12:23:59 am
i would try creating (or finding) a grey scale horizontal line or bar-like texture and use that as the displacement map layer for the displacement map effect on the layer/footage to be distorted. then animate the max horizontal displacement value (set vertical displacement to 0)
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
