Does somebody know how to create smoething like this?
Hans Meier
on May 14, 2016 at 7:39:02 pm
Well i saw this on youtube and i want to recreate this.
https://gyazo.com/7cb632c241bf0af655a9bfb02d4fe779
Is this even possible only in After Effects?
Would like to hear an answer!
Wallace Adrian D'Alessio
Re: Does somebody know how to create smoething like this?
on May 16, 2016 at 1:28:48 pm
Unless what you are doing is going out to a paying customer ( if you are doing it just for yourself)
Download and use that footage as a layer.
If you need to recreate this as your original work Just make a shape layer of color with a black spot, add a gradient effect to get the nice shading
Then scale it through the range of center sizes you need and precomp that/
Use that precom to clone as many layers as you want.
There would be multiple ways to stagger them for time to get the cascade effect.
An expression can be written or modified from a web downloaded script to keep the scaling proportional over time. if you just wanted to animate shape layers.
Whether you are confident enough to animate repeated shape
layers with an expression or clone some time - scale precomped footage for layering there are many variations possible.
Starting out making a single shape laye and scaling it over time will give you a starting point to understanding how you could make it work.
Adrian D'Alessio aka; Fluxstringer
fluxstringer@gmail.com
http://www.facebook.com/FluxStringer
http://www.linkedin.com/in/fluxstreamcommunications
http://twitter.com/FluxStringer
http://mog.com/FluxMuse
