3D layer shadow diffusion- want HARD edges
Craig Huff
on May 14, 2016 at 5:36:18 pm
Hello, I have a 3d layer that I have casting a shadow onto another 3d layer. The layer casting the shadow has light transmission set to 100%. As you can see in the image, despite the lights shadow diffusion being set to 0, my shadow still has a soft edge- any ideas how I can get it to a hard edge? Thanks in advance!
Wallace Adrian D'Alessio
Re: 3D layer shadow diffusion- want HARD edges
on May 16, 2016 at 1:13:06 pm
Did you try reducing the cone feather? Or reducing the cone angle?
Do you have a layer effect shadow turned on as well?
Adrian D'Alessio aka; Fluxstringer
fluxstringer@gmail.com
http://www.facebook.com/FluxStringer
http://www.linkedin.com/in/fluxstreamcommunications
http://twitter.com/FluxStringer
http://mog.com/FluxMuse
Michael Szalapski
on May 16, 2016 at 2:47:19 pm
You might try to bump up the resolution of your shadow map.
- The Great Szalam
Craig Huff
on May 16, 2016 at 3:55:11 pm
Thank you both for the replies. I did already try playing with the cone angle/feather, no luck. Tried a higher resolution for the layer casting the shadow (i think that's what you meant?), and no luck. I've attached an image of the settings on my shadow casting layer.
Craig Huff
on May 16, 2016 at 3:59:33 pm
Huzzah! I wasn't familiar with the Shadow Map option in Comp Settings. I just upped that and it's all good. Thanks Michael!
Michael Szalapski
on May 16, 2016 at 4:06:09 pm
Hooray! :)
- The Great Szalam
