250gb ssd kinston enough for cache ?
hanna dean
on May 12, 2016 at 6:50:15 am
i purchased another ssd coming tomorrow is this 250gb ssd enough for caching i work on small clips not large clips such as 700mb i work on file size less then 100mb less then 3 min videos.
Wallace Adrian D'Alessio
Re: 250gb ssd kinston enough for cache ?
on May 12, 2016 at 8:26:48 am
Yes, of course it is big enough.
But big projects and or big frame sizes will fill it faster than you will believe.
So purge caches often.
Save finished clips and resources on a different drive.
Adrian D'Alessio aka; Fluxstringer
fluxstringer@gmail.com
http://www.facebook.com/FluxStringer
http://www.linkedin.com/in/fluxstreamcommunications
http://twitter.com/FluxStringer
http://mog.com/FluxMuse
Walter Soyka
on May 12, 2016 at 4:51:44 pm
[Wallace Adrian D'Alessio] "Yes, of course it is big enough. But big projects and or big frame sizes will fill it faster than you will believe."
Agree to both. It's not about the size of the original files, it's about the size of your raster, the number of layers, and the length of the project.
[Wallace Adrian D'Alessio] "So purge caches often."
The cache is self-pruning; it automatically deletes older cached layer-frames to make room for new ones without the user having to manually purge.
Walter Soyka
on May 13, 2016 at 1:49:32 am
When you figure out your big project bins are not "self pruning " enough
Thank Adobe that they still give you controls to make room.
This screen shot is from the prefs >cache panel of the latest AE CC May of 2016
Do what you want.
Walter Soyka
on May 13, 2016 at 5:08:05 am
[Wallace Adrian D'Alessio] "When you figure out your big project bins are not "self pruning " enough. Thank Adobe that they still give you controls to make room."
You're absolutely right that the conformed media cache does not automatically delete old items. I was referring to the disk cache, which does.
Walter Soyka
Daniel Borba
on May 16, 2016 at 7:48:04 pm
Walter, When does it delete the files from the disk cache? When you quit the after effects?
Daniel B.
