ExtendScript: Test if plugin exists
Mike Sevigny
on May 11, 2016 at 9:58:39 pm
Hey guys,
Wondering if there's a quick way to test for a plugin by name without going through the directories and looking for the actual file.
I've tried cycling through the effects until it finds it by name but it takes a few seconds.
effectExists = 0;
for (i = 0; i<=app.effects.length; i++) {
if (String(app.effects[i].displayName) == "EFFECT_NAME") {
effectExists = 1;
break;
Right now I've resorted to programmatically creating a comp, then a solid and 'trying' to add the effect to generate my true/false value.. then deleting those elements.
try{
tempComp = app.project.items.addComp('tempComp', 40, 20, 1, 1, 1); // Create new Comp
tempSolid = tempComp.layers.addSolid([1,1,1],'tempSolid', 40, 20,1,1)
tempSolid.Effects.addProperty("EFFECT_NAME");
tempSolid.source.remove();
tempComp.remove();
effectExists = 1;
}catch(err){
effectExists = 0;
There must be a better way.. I wasn't able to find anything in the manual. Thanks for the help..
Mike Sevigny
Walter Soyka
Re: ExtendScript: Test if plugin exists
on May 12, 2016 at 5:34:15 pm
Maybe take advantage of the fact that Ae effects are listed in the Effects menu? Check out this example:
effectMenuName = "Levels";
if (app.findMenuCommandId(effectMenuName) == 0) effectExists = false else effectExists = true;
alert(effectExists);
Walter Soyka
Mike Sevigny
on May 12, 2016 at 11:41:28 pm
That works beautifully..
Thank you as usual Walter, you're a machine.
Mike Sevigny
