Creating an animated deformed mesh - how???
Doerte Hoelzemann
on May 10, 2016 at 11:38:50 am
Hey there,
I have to make an animation of the space time, using a deformed mesh and planets in 3d space. Please see the links below to get an idea.
I´m working with after effects and have tried freeform Pro and trapcode Mir but I don´t know how...
Can anyone give me an idea?
http://static3.tagblatt.ch/storage/org/2/0/1/2328102_1_9f2fe577.jpg?version...
(Animaton starts at min.1:30)
Cheers and thanks, Doerte
Tudor "Ted" Jelescu
Re: Creating an animated deformed mesh - how???
on May 10, 2016 at 2:30:26 pm
FreeForm Pro is quite easy to use for that. You can generate the grid in AE on a Layer you use for texture or choose to render the mesh from FF Pro.
You need the to choose as displacement map a precomp that has the same size as the layer you displace (mesh. Inside the precomp you need to create a animation of shapes in shades of gray that you can use for displacement. Radio Waves with blur for example can generate ripples:
Tudor "Ted" Jelescu
Senior VFX Artist
