RGB gone wild
Bob Cole
RGB gone wild
on May 9, 2016 at 11:50:27 pm
I set up a color expression layer, and input an RGB value. All fine.
When I went to put in a new RGB value, I found that on its own, the RGB had changed from the 0-255 range to ranges in the thousands.
What's going on here? I've tried rebooting, etc.
I'm using AE CS5.5, trying to wean myself off the subscription.
Thanks.
Bob C
Chris Wright
Re: RGB gone wild
on May 10, 2016 at 1:04:52 am
i find that working in projecting work space 16 bit gives 0-16,235 and 8 bit 0-255 and 32 0-1
you can use linear() expression if you want.
Bob Cole
Re: RGB gone wild
on May 10, 2016 at 1:43:04 am
Brilliant! Thanks so much! That is exactly what happened, as I had to switch from 8-bit to 16-bit output.
How do you deal with the translation, when you are given 0-255 values for RGB and you have to work in 16-bit space?
Thanks again.
Bob C
