Popping up many dots
Tad Marsik
on May 9, 2016 at 4:43:27 pm
Hello, first of all thank you for this forum. It helped me a lot since I'm learning in After Effects.
Now I've got into a trouble because I can't find a solution on the internet and I can't think of something... normal.
Let's say I have this background. It was made with halftone function in Photoshop.
http://i.imgur.com/HJt7bnV.png
I'd like to make an intro with identical background and those circles to be animated. Like popping up from 0% scale.
Is there an easier way how to do it in After Effects? I started with AE a few days ago so I came up only with making every single circle and change sizes manually.
Thank you for responses, I really appreciate it.
Joseph W. Bourke
Re: Popping up many dots
on May 9, 2016 at 6:27:56 pm
This tutorial might help you out:
http://lesterbanks.com/2014/03/create-easy-halftone-effect-ae-using-shape-l...
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Richard Herd
on May 9, 2016 at 7:00:38 pm
You can animate it with shape layers and a repeater. If you have you used expressions before, modifying a "drag me" expression on the radius or scale parameter will get you there too:
//applied to a blur effect, for example, causes the blur intensity to increase as the to points get closer;
point1=transform.position;
point2=thisComp.layer("dragme").transform.position;
delta=sub(point1,point2);
distance=length(delta);
linear(distance, 0, 80, 40, 0);
I can't remember where I got the dragme expression, but I didn't write it.
