Mask mode selection toggle missing and menu modes ghosted?
Jeff Cottle
on May 6, 2016 at 5:01:12 am
Hello, for the 1st time i've seen a mask in my AE project has no Mode Selection toggle and its modes in the menu are ghosted(gray).
I hoped anyone familiar could please tell me how to re-enable a mask mode toggle and\or re-activate menu mask modes?
Thanks for any help,
J
Kalle Kannisto
Re: Mask mode selection toggle missing and menu modes ghosted?
on May 6, 2016 at 6:52:00 am
The mask is not properly closed. Right-click on the mask and select Mask Path Shape > Closed.
Jeff Cottle
on May 7, 2016 at 2:35:29 am
Thanks much Kalle,
that did the trick quick
J
Jeff Cottle
on May 7, 2016 at 2:50:24 am
Hi guys, spoke a bit too soon: should have asked how to enable mask mode selection for all keyframes simultaneously?, if possible,.
Thx again,
J
Wallace Adrian D'Alessio
on May 7, 2016 at 1:00:37 am
What color bitspace are you working in?
A lot of things are not available for certain modes of high or low color bits.
Read some readily available info.
Adrian D'Alessio aka; Fluxstringer
fluxstringer@gmail.com
http://www.facebook.com/FluxStringer
http://www.linkedin.com/in/fluxstreamcommunications
http://twitter.com/FluxStringer
http://mog.com/FluxMuse
Jeff Cottle
on May 7, 2016 at 2:42:52 am
Hi Mark,
mask mode selections' re-enabled, but when i determine colorspace i'll reply it, unless you might say which menu displays it?
Appreciate it,
J
on May 7, 2016 at 4:29:06 pm
bottom of project panel. Or in composition setting panel advanced tab.
