i purchased this ssd 500gb is this good
hanna dean
on May 4, 2016 at 5:04:15 pm
http://www.ebay.co.uk/itm/NEW-Samsung-SSD-850-EVO-2-5-Inch-500GB-Solid-Stat...
i just purchased this coming next week is this any good for my after effects caching.
will this be more faster then its not ,currently everything is working on same local sata drive , also this drive is not so bad keeping up the speed , wonder how this new ssd will be please tell me.
hanna dean
Re: i purchased this ssd 500gb is this good
on May 4, 2016 at 5:17:57 pm
current pc specs
1tb sata hdd
500gb sata
gtx 750ti
i7 6700k
16gb ram
will this ssd be fast on my machine,currently using adobe no slow down renders fast also in timeline it acceps all resolution and no slow downs
Dave LaRonde
on May 4, 2016 at 6:17:03 pm
It's a good capacity for AE work. But usually, you ask such questions BEFORE you decide to buy.
Dave LaRonde
Promotion Producer
hanna dean
on May 4, 2016 at 9:47:53 pm
i will have it plugged from external case via using port 3 will this still work this way or do i need to connect it inside
Walter Soyka
on May 5, 2016 at 1:42:04 pm
The cache drive benefits from the fastest possible connection. This is usually internal.
Walter Soyka
hanna dean
on May 5, 2016 at 5:22:52 pm
so should i have this connected as interal drive always.
also my pc can stay on more then 24 hours without shut downs so can that damage the drive
Walter Soyka
on May 5, 2016 at 5:36:13 pm
[hanna dean] "so should i have this connected as interal drive always."
Yes.
[hanna dean] "also my pc can stay on more then 24 hours without shut downs so can that damage the drive"
Well, eventually any piece of hardware will fail, but I'm running a bunch of Samsung SSDs 24/7.
Walter Soyka
