Masking question - link to file included
Paul Rijkaard
on May 4, 2016 at 4:46:36 pm
Hi
I am attempting to create an animation using a noise field via the cell pattern effect.
The animation will consist of geometrical shapes which will be masks for various colour patterns.
how can I use the random cell pattern to make the edge of the shape oscillate slightly?
i.e. the shape consists of lots of 'random dots' but has a hard edge, how can I isolate the edge so that it is 'fuzzed' as part of the effect
and the edge itself appears to approximate a circle rather than have a hard edge.
to do this I imagine the edge of the circle needs to be isolated.
many thanks in advance
here is a link to the file (AFX cc 2014 file)
https://www.dropbox.com/sh/d7paomdmyktc21y/AADPBGrJaylwq9AbYsjHEnIRa?dl=0
Kalle Kannisto
Re: Masking question - link to file included
on May 5, 2016 at 8:14:29 am
I would do this with cc ball action on a transparent background.
Like this:
10056_test1a.aep.zip
Paul Rijkaard
on May 5, 2016 at 11:42:46 am
Very helpful thank you
can you offer any advice using expressions to add further randomness to the movement of the circles.
I believe that the cell pattern effect is a random distributionon a frame by frame basis, wheras the circles in cc ball appear to move on a path or a walk.
many thanks
Paul
Kalle Kannisto
on May 5, 2016 at 2:02:32 pm
They both move in a wiggle fashion (kinda like following a path), with the difference that Ball action has options for rotation and twist. It doesn't look like they are using the same position wiggle formula, but the result is pretty similar.
If you want a random placement on each frame, you can use the expression
random(10000)
instead of the current
time*100
for the instability state.
