Particular Size/Opacity Over Life
Scott Smith
on May 3, 2016 at 1:14:44 pm
Particular size and opacity over life is not responding I'm using adobe after effects cc 2015.
Even using default particular effect with the only thing changed being the size/opacity over life it still isn't responding.
setup is as follows, new solid>add particular>size over life (decaying). this has no effect. However,If i save the file and open in 2014 the effect works as its meant to.
I revert back to cc 2014 at them moment but would appreciate suggestions regarding what could be causing the bug.
Thanks in advance
Scott
Walter Soyka
Re: Particular Size/Opacity Over Life
on May 3, 2016 at 1:47:40 pm
Make sure you're up-to-date on Particular. You must be on at least Particular 2.2.5 for compatibility with Ae CC 2015.
Walter Soyka
