AE Script for Importing Assets and Creating Comps based on filenames
Ashley Bryan
on Apr 30, 2016 at 12:23:02 pm
Hello, I am looking to figure out how a script that could be created to do the following in Adobe After Effects:
Say I have multiple png files in pairs and one folder, to be put into seperate compositions, a background layer, and a text layer to go above the background layer, like so:
...ect....ect...
I want to be able to find a way to import these pngs, and create a 15-second (or another length to be applied across all) composition for each pair, so here in this case three compositions:
AP15_00001 (Comp 1)
AP15_00002 (Comp 2)
AP15_00003 (Comp 3)
...ect...ect...
and inside each composition the text layer and the background layer:
AP15_00001 (Comp)
Whilst the naming will be different I'll make the end format of the pngs the same, the text layer will be just the name of the stockcode, and the bg layer will have _BACKGROUND at the end.
Is there a way that this can be automated using a script?
Dave LaRonde
Re: AE Script for Importing Assets and Creating Comps based on filenames
on Apr 30, 2016 at 3:31:05 pm
Not that I know of. The problem -- image sequences have no inherent frame rate.
Dave LaRonde
Promotion Producer
Walter Soyka
on May 1, 2016 at 10:34:16 am
Yes, it's totally possible to do this with scripting, but as Dave notes, I doubt that one exists that does specifically what you want.
If you're interesting in getting started with scripting, check out the AE CS6 Scripting Guide (still valid today):
http://blogs.adobe.com/aftereffects/files/2012/06/After-Effects-CS6-Scripti...
This developer page also lists the addenda to the that guide since CS6:
http://www.adobe.com/devnet/aftereffects.html
Check out the sample script Smart Import.jsx that ships with Ae as a starting point.
Walter Soyka
