After Effects CS6 dynamiclinkmanager.exe Error
Viktor Voscek
on Apr 29, 2016 at 5:11:48 pm
Hello,
This is my first time posting here, and sorry for my english
I have problem with After Effects on startng. Everything loads and then it gets stuck at the "Intializing user Interface" and 2 minutes after it gives me error [link below]
I´ve tried everything; re-installing 2 times, downloading dynamiclinkmanager.exe from others users, set folder privileges and literally every "fix" from YouTube and other forums. And it still giving me the same error. I dont have Quicktime installed,I dont have any plug-ins I have turned off all visual setting in Windows because my computer is slow. Could that be the problem?
Error: https://gyazo.com/c6da388b3a3a66b290c165ec006d997e
Voscek
Amateur editor, still learning alot :3
Walter Soyka
Re: After Effects CS6 dynamiclinkmanager.exe Error
on May 1, 2016 at 10:25:34 am
Re-installing doesn't reset preferences. Try that, for both Ae and Premiere. Hold Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) while the application is starting.
Walter Soyka
Viktor Voscek
on May 1, 2016 at 11:03:59 am
What is supposed to happen? Because application was starting normally and still the same error appears. Also I deleted preferences manually after uninstall.
Viktor Voscek
on May 1, 2016 at 11:14:21 am
Nevermind got it to work, deleted preferences but it still giving me the same error :/
