Shortcut for "Create shapes from vector shortcut"
Nikitas Mikas
on Apr 29, 2016 at 3:56:51 pm
Hallo I need to know if there is a shortcut for the "Create shapes from vector ".
For the next days i will be importing hundrents of .ai files and transform them in shapes.
If there is a shortcut it will save me tons of time.
Cassius Marques
Re: Shortcut for "Create shapes from vector shortcut"
on Apr 29, 2016 at 5:54:17 pm
If the command sits on any menu you can either:
Add or change the shortcut to it by messing with the shortcuts file. SEE HOW
If it ain't there you can add a script to run it. Scripts can run any menu command. You can then place that script on AE's script folder and you'll be able to add a shortcut to it using the above method. You should google search for that.
If it is only a context right click option. There's no way you can add a shortcut to it as far as I know. (but this is not your case).
Cassius Marques
http://www.zapfilmes.com
Nikitas Mikas
on Apr 30, 2016 at 7:29:20 am
Thanks for guiding.
Unfortunatelly searching the internet did not came up with more than "re-arranging" the shortcuts!
I found nothing concerning the create a shortcut which is not provided!
In case you came out with something I will be more than HAPPY.
Cassius Marques
on May 2, 2016 at 6:20:23 pm
I wrote one to run the command. (its just a call for the item, you can edit if you ever need to do another).
Download here 10040_01createshapesfromvectorlayers.jsx.zip
You should place it in your AE folder under "\Support Files\Scripts". The reason it has a "01" before its name is for it to be the first file on the folder. This way AE sees it under File->Scripts.
All scripts there can be shortcutted under the "ExecuteScriptMenuItem01" in your shortcuts file.
Make sure you don't add a duplicate shortcut for it. Otherwise it will take precedence over this.
Cassius Marques
Nikitas Mikas
on May 3, 2016 at 6:53:59 am
WORKED
THANKS
