How can i align my text on this airline
hanna dean
on Apr 29, 2016 at 12:56:18 am
i want to align my custom text on this body , exactly same as the original text under it , how can i do that.
http://s32.postimg.org/hbrui0slx/2016_04_29_015251.jpg
please check snapshot link above
hanna dean
Re: How can i align my text on this airline
on Apr 29, 2016 at 1:27:02 pm
will anybody comment on this cheers.
Cassius Marques
on Apr 29, 2016 at 5:44:03 pm
Try the mesh warp or the reshape plugin. But if the airplane rotates too much, you end up having trouble keeping it in shape.
Cassius Marques
http://www.zapfilmes.com
Kalle Kannisto
on Apr 29, 2016 at 8:12:24 pm
Make a precomp with a tight crop around the text, larger than you need at any point in the footage. Use Mesh Warp with 1 column and 1 row and give it the needed shape that follows the contour, but discounts the perspective -- basically that missing additional distortion coming from the roundness of the plane surface that perspective distortion doesn't provide. Then use corner pin to stick it on the plane. I assume you're tracking the current text for corner pin.
If there is a lot of "turn-table" motion in the footage you can animate the Mesh Warp.
hanna dean
on Apr 29, 2016 at 8:20:39 pm
yes sir am currently using corner pin data using mocho pro
