Layer Control to drive opacity of a single layer
Craig Kristensen
on Apr 28, 2016 at 8:38:30 am
I have a comp with hundreds of layers (all with an opacity of 0), and I need an easy way to select just one layer and make it visible.
Is this possible with "Layer Control"? Possibly in combination with a Check box that sets the opacity value to 100 when checked?
Craig
Craig Kristensen
Re: Layer Control to drive opacity of a single layer
on Apr 28, 2016 at 9:11:50 am
I have been trying to get something like this to work.
I have a text layer that reads the value of the Layer Control using:
thisComp.layer("— SELECT").effect("Selector")("Layer").name
And then using this on the opacity for each layer to check if the "FRANCHISE NAME" equals the name of the layer. If so, "then opacity = 100"
ifi(thisComp.layer("FRANCHISE NAME").text.sourceText = ("thisLayer.name")) 100 else 0;
But I'm having some syntax troubles.
Walter Soyka
on Apr 28, 2016 at 9:53:35 am
[Craig Kristensen] "I have a text layer that reads the value of the Layer Control using:"
Layer Controls cannot be keyframed, so this value will be constant throughout the comp. It doesn't sound like that's what you want.
[Craig Kristensen] "ifi(thisComp.layer("FRANCHISE NAME").text.sourceText = ("thisLayer.name")) 100 else 0;
Here's the correct syntax:
if (thisComp.layer("FRANCHISE NAME").text.sourceText == thisLayer.name) 100 else 0;
1) It's "if" not "ifi".
2) Equality comparison uses "==" not "=".
3) There is no reason to enclose thisLayer.name in quotes and parentheses. "name" is an attribute of the object called "thisLayer".
Walter Soyka
Craig Kristensen
on Apr 28, 2016 at 10:02:37 am
Works perfectly!
Is it possible to use a Layer Control to select layers in a different comp?
Walter Soyka
on Apr 28, 2016 at 10:19:31 am
[Craig Kristensen] "Is it possible to use a Layer Control to select layers in a different comp?"
No, but you could refer from your main comp to a layer control effect on a layer in a different composition:
comp("OTHER COMP").layer("— SELECT").effect("Selector")("Layer").name
Walter Soyka
Wallace Adrian D'Alessio
on Apr 29, 2016 at 3:21:04 pm
You can precomp . Then drag out timelines for the precomp and the comp and then pick whip across.
I have done it.
Adrian D'Alessio aka; Fluxstringer
fluxstringer@gmail.com
http://www.facebook.com/FluxStringer
http://www.linkedin.com/in/fluxstreamcommunications
http://twitter.com/FluxStringer
http://mog.com/FluxMuse
