How can I make camera layer exclusive to one single layer
kewei du
on Apr 26, 2016 at 6:41:58 pm
How can I make camera layer exclusive to one single layer, not effecting other layers ?
cause I love to have different cameras for different clips, some of them are next to each other, if I put the cameras meet each other seamlessly, plus If I use different positions for each camera, it will be super weird at the transaction, cause the depth will just jump from one to the other.
That's why I am thinking, if I can make the camera just affect each own clip, then I can have a smooth transaction, and each camera maintains each own depth.
Richard Herd
Re: How can I make camera layer exclusive to one single layer
on Apr 26, 2016 at 7:15:38 pm
Try precomposing the camera and layers you want together. In this way, you'd have 2 (or more) precomps, and inside each precomp would have all of the camera moves, etc.
Shift-select the layers you want and then choose Layer > PreCompose
toggle the "collapse transformations" to get different results for your precomp -- experiment a bit. Collapse Transformations is the weird looking sun-looking switch in the layer panel, next to the layer name.
kewei du
on Apr 26, 2016 at 7:28:31 pm
That's actually really smart! thanks!
