linking keyframes from 2 layers or nulls to make strong track
hanna dean
on Apr 24, 2016 at 12:09:12 am
is it possible to link 1 3d image layer to 2 track null points to keep the image still without shaking ?
1 null on left side of the object
1 null on right side of the object
3d image layer in middle linking to 2 nulls null-left< 3dimage >null-right
Jon Simpson
Re: linking keyframes from 2 layers or nulls to make strong track
on Apr 25, 2016 at 12:02:21 am
This reads like an expression solution but I am just learning that myself.
hanna dean
on Apr 25, 2016 at 2:05:52 am
what plugin i can get that does this mate
Walter Soyka
on Apr 25, 2016 at 10:18:01 am
[hanna dean] "is it possible to link 1 3d image layer to 2 track null points to keep the image still without shaking ?"
It's possible to determine the midpoint of two points; whether the midpoint is still depends on the tracked points.
Here's the expression. Alt+click on the position stopwatch of the layer you'd to set at the midpoint between Null 1 and Null 2. (The formula for midpoint is just the average of each of the two points coordinates.)
null1Pos = thisComp.layer("Null 1").transform.position;
null2Pos = thisComp.layer("Null 2").transform.position;
midPointPos = [ (null1Pos[0] + null2Pos[0]) / 2, (null1Pos[1] + null2Pos[1]) / 2, (null1Pos[2] + null2Pos[2] ) / 2 ];
Walter Soyka
