Confused
Oliver Kulawiak
Confused
on Apr 23, 2016 at 11:09:15 pm
Hello, I'm back again and I have the question.
How do I make effects ex. Twitch (amount) to increase when bass grows up ?
And I need the Trapcode Sound Keys way.
Thanks.
Kalle Kannisto
Re: Confused
on Apr 24, 2016 at 6:41:48 am
What have you done so far? Have you created Soundkeys keyframes from the audio?
If so, you link the Twitch effect amount to the keyframes with the pick whip.
Oliver Kulawiak
Re: Confused
on Apr 24, 2016 at 10:05:07 am
I applied Output 1 and keyframes for basses was created.
the pick whip doesn't give the results I wanted.
I want twitch amount to change between basses.
Bass drop = 100 then shrinking
Oliver Kulawiak
Re: Confused
on Apr 25, 2016 at 6:04:10 pm
i remember there was a method with "thisComp.layer("layer").effect("Sound Keys")("Output 1") and "value" but i can't put it correctly.
Soham Jani
Re: Confused
on Apr 29, 2016 at 2:46:22 pm
Well, you might have to keyframe it manually if you can't pickwhip it etc.
"It's all around us Neo, temporary constructs of time....."
