How to create this opening sequence?
Soham Jani
on Apr 22, 2016 at 9:41:33 pm
Is there a way to re-create the opening of this video, from where the jet fuel of the plane turns into the video?
"It's all around us Neo, temporary constructs of time....."
Kevin Camp
Re: How to create this opening sequence?
on Apr 22, 2016 at 11:50:08 pm
if you're talking about the 4 or 5 second mark where the shot shatters like glass, then I think you could try the shatter effect, setting the shape pattern to glass to get started with.
and then cc pixel poly on another layer to create the finer particles (or shatter, with higher shape repetitions, or another particle system)
with shatter, you can also create your own shatter map to get glass shards more like the example. you should be abel to find several tutorials on that.
you'll need to finesse that more, but I think you can get close.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Jon Simpson
on Apr 25, 2016 at 12:11:28 am
This looks like a combination of a 3rd party plugin and AE effects.
