Camera blur map / depth map showing as a solid white square on black
Samantha Derochie
on Apr 21, 2016 at 10:02:43 pm
I was trying to use the frischluft lenscare plug in, but when I select a layer to use as a depth map, it just ignores the map and blurs only a rectangle in the center of the frame at full and everything else at none. When I show the depth buffer, it show a white rectangle on black, instead of the grayscale ramp I have on my depth map layer. The same thing happens when I try and use AE's built in camera lens blur effect. I feel like I'm missing something very obvious here, but I can't seem to figure it out.
Thanks for your time!
Tudor "Ted" Jelescu
Re: Camera blur map / depth map showing as a solid white square on black
on Apr 22, 2016 at 6:47:33 am
Post a screen grab of your layer setup, the comp window and your depth map.
Tudor "Ted" Jelescu
Senior VFX Artist
