Same image Different resolution in AE en PS
Jason Reese
on Apr 21, 2016 at 2:20:22 pm
Link to File : https://f1.creativecow.net/9999/exr-for-ae-en-photoshop#10000
Hey everyone, first of all i usually never post on forums. (I'm a hardcore reader). But i could not find any solution to this problem.
I have a rendered footage in openexr (exr) format. When i import this in AE or Premiere the resolution is 479 x 853.
It should be 480 x 854.
The image is rendered in 480 x 854.
When i open this in photoshop the dimensions are correct => 480 x 854
So in AE en Premier its 1 pixel less from every side.
I will upload the image so you can see it your self.
PS: My workaround is to write a little script in photoshop which opens and saves the files. After doing this AE opens the files with the normal resolution, but i have so many files...i wish i could know what's going on.
Dave LaRonde
Re: Same image Different resolution in AE en PS
on Apr 21, 2016 at 6:05:52 pm
If you count from 0 to 479, you count 480 numbers.
If you count from 1 to 480, you count 480 numbers.
Is this a simple counting mistake?
Dave LaRonde
Promotion Producer
Jason Reese
on Apr 21, 2016 at 7:02:01 pm
Dear Dave,
Thank you for your both replies on here and on other forum.
I don't think that this is a counting issue. Because when i open the file in photoshop and just save it. Then open it In after effects i get the real 480 x 854 resolution.
When I drag it to my layer it creates a composition with 853 x 479. If i change the composition to 854 x 480 it gets blurry.
In blended i can open it normally. It shows the right resolution. So for some reason if i open the file in AE the resolution is 1px less from each side.
My only option now is to make a small action script and batch open and save in exr again. I just tried on one and it worked but i truly wanted to know what's going on.
thanks in advance
Kevin Camp
on Apr 22, 2016 at 5:43:58 pm
it is a curious anomaly, and you might want to file a bug report. i'm seeing the same issue in cc2014 too...
the blur issue when you resize the comp is due to the anchor point shifting half a pixel. if you set the anchor point back to whole numbers it should be sharp again... not sure if that helps you much...
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Jason Reese
on Apr 23, 2016 at 1:20:13 am
Wow, It HELPED ALOT! I did not noticed the shift! I made it whole number and bam! Thanks Kevin, i'm really happy!
Now i can get back!
