Time Display Settings
Charles O'Connor
on Apr 20, 2016 at 12:17:16 pm
I understand how to switch from frames to seconds, but I am having trouble figuring out how to subdivide my seconds in my composition. My project is 10 seconds long, and I am only able to select one second on the mark in my timeline. How can I get the program to display different intervals such as x.1 seconds? When I scrub through it just snaps to each second and I have no way to place a keyframe at, say, 5.5 seconds.
Soham Jani
Re: Time Display Settings
on Apr 20, 2016 at 1:03:08 pm
Did you try changing the settings in the composition settings? It might be in the After Effects settings.
"It's all around us Neo, temporary constructs of time....."
Walter Soyka
on Apr 20, 2016 at 2:30:50 pm
[Charles O'Connor] "My project is 10 seconds long, and I am only able to select one second on the mark in my timeline. How can I get the program to display different intervals such as x.1 seconds? When I scrub through it just snaps to each second and I have no way to place a keyframe at, say, 5.5 seconds."
That will be based on your frame rate. For example, if your comp is 30 fps, 5.5 seconds will be 5 seconds and 15 frames.
Walter Soyka
