after effects + pftrack question why is my object moving but nulls are still
hanna dean
on Apr 20, 2016 at 8:38:38 am
let me break it down quick what i have done.
1: rendered mp4 to jpeg sequence from after effects.
2: made solid track in pftrack and exported selected tags to .ma
3: imported .ma with jpeg sequence.
now when i insert an image or text i make it 3d layer then try to move it freely ,once in position were i want i use pick wip to assign to null object , some how sometimes my object moves as i scroll threw the shot but my nulls remaian still , whats wrong.
second wiered problem fps in pftrack
after effects detects footage original fps 29.97
when i import the footage , then i go to edit format , i set my fps there matching after effects how ever once i export the tracking data .ma for after effects , the fps sets out to be wrong which is 30.fps or other numbers not matching original fps.
how do i fix this please help
