Tracking question - is image sequence better to track or .mov + mp4
hanna dean
on Apr 19, 2016 at 10:24:17 pm
kindly tell me if image sequence is better to track then .mov .mp4
i have
pf track
mocha
after effects
synth eyes
boujo
kindly tell me what is the best so i can get beter results.
Dave LaRonde
Re: Tracking question - is image sequence better to track or .mov + mp4
on Apr 19, 2016 at 10:31:42 pm
An image sequence is much better than the mp4, which is highly compressed. AE has to do a lot more thinking, and the rare error has been known to occur.
But if you track QT movies in the PNG, Animation, Photo JPEG or ProRes codecs, there's no problem -- they used a different kind of compression, which requires a lot less thought from AE.
Dave LaRonde
Promotion Producer
Claude Rozsa
on Apr 20, 2016 at 7:40:55 am
Hi Dave, I'm not I understand your explanation in the first sentence. I'm not a pro and use those programs as a hobby but try at least to learn to do it well.
What do you mean by "An image sequence is much better than the mp4".
For instance I have the following shot: It is a long zoom from the middle of one of the streets of Pompeii. I intend to give the impression that the buildings on both sides of the street return to their original look before the Vesuvius eruption. For this I have still image (png) of the walls etc.My clip is a 20seconds mp4 with theses characterics:
<a href="https://images.creativecow.net/282881/screenshot_wed_apr_20_09.30.35.png"><img src="https://i1.creativecow.net/u/282881/screenshot_wed_apr_20_09.30.35.png" border="0" /></a>
Do you mean that I should transform the clip into a sequence of 500+ single images? How do you that? The question may look silly but I don't know the way tot do it. Thanks
hanna dean
on Apr 20, 2016 at 8:39:53 am
youtube after effects image sequence
David Fleury
on Apr 20, 2016 at 11:02:07 am
It is a simple export setting from AE. Yes it will create 500 (x) images per frame so make sure you have them going to a folder and not to your desktop which I have done more than once :)
Then when you want to import the sequence into your editing program make you sure you have import image sequence box checked or you will only get one frame.
Claude Rozsa
on Apr 20, 2016 at 11:04:33 am
thanks; I'll try that
