Hide layer from effects?
Michael Dominic
on Apr 19, 2016 at 12:54:29 pm
Is it possible to hide a specific layer from an effect that is above it?
For instance if I have 4 layers:
Curves
Blur
Shape
Can I have the shape layer NOT effected by the curves? If so can it only be hidden by the curves but still effected by the blur?
Thanks.
John Cuevas
Re: Hide layer from effects?
on Apr 19, 2016 at 1:00:13 pm
Assuming an adjustment layer with the effect. I think what you need to do is create 2 adjustment layers(one with curves, one with blur), and sandwich the shape layer in between them.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Michael Dominic
on Apr 19, 2016 at 1:04:47 pm
That won't work, and it's not really the question. If I do that it changes the look of the blur.
The question again is is there a way to hide a single shape layer from a single effect?
Walter Soyka
on Apr 19, 2016 at 2:23:24 pm
[Michael Dominic] "The question again is is there a way to hide a single shape layer from a single effect?"
No. Adjustment layers are applied to the composite of every layer below them. You cannot exclude a specific layer from an adjustment layer.
You could, however, limit the impact of the adjustment layer with a track matte.
Walter Soyka
