Render Settings are messing with me....
Paul Fisherman
on Apr 16, 2016 at 7:18:52 pm
In the Cinema 4D Lite for After Effects CC 2015, I go to the render settings and when I go to the save tab I don't see the option for where to render it to and the codec for the file. Help?
"It's all around us Neo, temporary constructs of time....."
Cassius Marques
Re: Render Settings are messing with me....
on Apr 18, 2016 at 2:25:02 pm
Maybe because you should render out of AE and not cinema 4d.
Maybe they didn't add the output modules. I'm not sure, never tried. Just guessing.
Cassius Marques
http://www.zapfilmes.com
Walter Soyka
on Apr 18, 2016 at 6:54:27 pm
[Cassius Marques] "Maybe because you should render out of AE and not cinema 4d. Maybe they didn't add the output modules. I'm not sure, never tried. Just guessing."
This is correct. C4D LITE is intended to render through Ae via CINEWARE. It is not intended to render to files itself.
You can of course render out of any of the full versions of C4D.
Walter Soyka
Paul Fisherman
on Apr 19, 2016 at 3:57:05 pm
So how do I render out my object as a .png?
Walter Soyka
on Apr 19, 2016 at 3:58:13 pm
[Paul Fisherman] "So how do I render out my object as a .png?"
Build it in C4D LITE, put the C4D file into Ae as a CINEWARE layer, then render to PNG from Ae.
Walter Soyka
