1200 small layers in one composition, impossible to render!
Fredrik Andersson
on Apr 15, 2016 at 2:24:48 pm
I have a 10 second compostion with around 1200 layers, imported from a psd file. Each layer is around 1-3 kb (~30x30 pixels) and holds a simple expression to make it rotate independently in a semi-random way. The problem is, when I try to render the composition CPU goes up but nothing happens, it says "Rendering" and "Elapsed: 0 seconds". I keep refresh disabled throughout the process. Even when I remove the expressions, and just have a 10 second static composition, the rendering is stuck!
Is it the sheer number of layers that makes the rendering impossible?
Dave LaRonde
Re: 1200 small layers in one composition, impossible to render!
on Apr 15, 2016 at 4:46:46 pm
Since we know nothing about your AE version, your OS nor your computer, it's impossible to draw any kind of conclusion. Sorry.
Dave LaRonde
Promotion Producer
Fredrik Andersson
on Apr 15, 2016 at 5:01:36 pm
Yes, sorry, the post was uninformative! I'm on a late 2011 Macbook, Mountain Lion, After Effects 11.0. Anyway I got it to work by disabling multiprocessing. A bit embarrassing that the solution was so simple :)
