Make a video loop?
Kurt Barken
Make a video loop?
on Apr 12, 2016 at 6:48:52 pm
Hello! I am looking for a way to seamlessly loop a video (https://i.imgur.com/y6WuVeA.gifv). I saw someone use a technique a few years ago in which they used multiple time remapping keyframes to achieve a seamless loop, but I have not been able to replicate it. If anyone knows a method to seamlessly loop this video, that would be fantastic! Thanks for any help in advance!
Kalle Kannisto
Re: Make a video loop?
on Apr 13, 2016 at 6:48:45 am
One way is to find two spots, one in the beginning and one towards the end where the motion is similar, duplicate the footage and move the top layer so these two spots are in the same point in time, then use an animated masks to reveal the bottom layer. Then you need to put the beginning and end on the same frame (beginning on the first frame and end frame one frame before the first frame repeats).
