How to fix the Strip flash from shooting press conference video?
Ko Frank
on Apr 11, 2016 at 4:45:15 pm
I apologize to my bad English first.
After shooting press conference, I found a problem on the video.
That's the Flash light of camera is strip light.
(Just like this http://i.imgur.com/tvlCeyI.jpg )
I try to fix this with RE:VisionFX DE:Flicker. But the effect is not good.
Anyone know how to fix the video becomes normal flash?
(just like this http://i.imgur.com/cnFO8G8.jpg )
Paul Fisherman
Re: How to fix the Strip flash from shooting press conference video?
on Apr 11, 2016 at 6:39:49 pm
Wow, that might be a little tough. Um, I don't exactly know because I've never had this problem, but have you tried googling it? Maybe there's a plugin that removes just that?
"It's all around us Neo, temporary constructs of time....."
Dave LaRonde
on Apr 11, 2016 at 9:34:52 pm
If it's just the one frame that's the problem, you could do it in Photoshop.
If you prefer doing it in AE, import the problem frame. Add it twice to a comp. Using a feathered mask, eliminate the bright strip on the upper layer. Then use Levels and whatever extra effects you think you need to adjust the exposure, and come as close as you can to the exposure of the lower layer.
You will never get it perfect, but you don't have to -- it's just one frame.
Dave LaRonde
Promotion Producer
Kalle Kannisto
on Apr 12, 2016 at 6:05:15 am
Might be easier to duplicate the footage, offset it one frame and apply curves. Then keyframe opacity to 100% on the duplicate for those frames that you need to fix the flash for and otherwise keep it at 0%. Not automatic, but would look consistent with relative ease.
Chris Wright
on Apr 12, 2016 at 6:21:07 pm
if its only a few frames, you could use this
http://aescripts.com/pt_framerestorer/
you'd be surprised how well you can hide stuff with optical motion.
