add a definied comp in another comp with javascript
phil largilliere
on Apr 11, 2016 at 9:27:37 am
Hi every one
I wrote a script where I create a new comp, then I want to import a definied comp in this new one, but I can't find the way to do this.
myProject = app.project;
myProject.items.addComp("surComp",1920,1080,1,15,25);
var myComp = new Array();
for (i=1; i <= myProject.numItems; i++)
if (myProject.item(i).name == "Comp 1")
{ myCompNum = i - 1;
if (myProject.item(i).name == "surComp")
myProject.item(i).openInViewer();
//Add "Comp 1" as layer in this new Comp ???
Can you help me ??
Thank you so much
PH...
Walter Soyka
Re: add a definied comp in another comp with javascript
on Apr 11, 2016 at 10:13:53 am
You use the .add() method of a LayerCollection:
surComp = myProject.items.addComp("surComp",1920,1080,1,15,25);
{ comp1 = myProject.item(i);
surComp.openInViewer();
comp1Layer = surComp.layers.add(comp1);
Walter Soyka
phil largilliere
on Apr 11, 2016 at 10:32:47 am
Thank you !!
it works perfectly well !! I use to write this code, but I don't know why it doesn't work. Thanks again ;)
