Cinema 4D Render in 4K 60 fps -> Import to After Effects.
Candy Mustache
on Apr 7, 2016 at 5:29:24 pm
Hi there,
First post here.
I'm working in my first short movie in Cinema 4D and I decided to work in 4K 60 fps and I have some concerns.
I would like to render in openexr image sequence. What is the right way to import this in After Effects? I have to convert the sequence in 30fps?
Also there is a voice over and I have to synchronize it in cinema 4D (60 fps).
If I convert it in 30 fps, I will lose the synchronization?
Best regards.
Michael Szalapski
Re: Cinema 4D Render in 4K 60 fps -> Import to After Effects.
on Apr 7, 2016 at 6:16:51 pm
After Effects can handle 60 fps...
If you're planning to output 30 fps, why work in 60 though? That's just needless rendering time wasted.
- The Great Szalam
Dave LaRonde
on Apr 7, 2016 at 7:46:23 pm
Also, is there a good reason to work in 4K? There could be a few.
But if you are delivering in less than 4K, with no specific reason to work in it, you are again doing needless rendering; you won't gain additional image quality.
Dave LaRonde
Promotion Producer
