1 Pixel line black bar on export - not visible in comp
Emma Pierce
on Apr 7, 2016 at 10:41:20 am
Using a 1920 x 800 comp, square pixels, with 25fps which is 19 seconds long.
on H264 export its getting a tiny 1pixel black bar across the bottom, which doesn't appear in the after effects comp. I can't get rid of it on export. any help please?
Dave LaRonde
Re: 1 Pixel line black bar on export - not visible in comp
on Apr 7, 2016 at 3:47:41 pm
Try a different codec -- NOT h.264. A Quicktime in Photo JPEG comes to mind. See if the problem persists.
And how do you determine it's just one line, anyway? I'd be hard-pressed to say that definitively.
Also, I gotta tell you -- 1920x800 is an awfully weird resolution at which to work. What are you making? Furthermore, H.264 only renders properly to a strictly-defined set of resolutions... which could explain the black. I doubt 1920x800 is among them.
What kind of delivery specifications did the client give you for this project? "Make me a video", and nothing more, perhaps?
Dave LaRonde
Promotion Producer
