Fire Cannon (particle) shots that don't move when the emitter moves
James Poulakos
on Apr 4, 2016 at 8:49:14 pm
OK, so I'm trying to replicate the look of a Space Invaders game, where an icon at the bottom edge of the screen fires shots upwards, towards the top edge of the screen.
Using CC 2015.
I found "Cannon" in "Particle Playground" but, when I move the emitter around, all the shots that are already fired move along with the emitter. That's no good. I need each shot to keep moving without reference to what its emitter does next... like a cannon's shot.
The effect is attached to a solid that's same size as comp (HD).
What must I do to make cannon shots keep moving on their own instead of moving left and right when I move the emitter left and right?
I need about 20 or 40 shots fired. Otherwise I'd have done this by hand. Hoping for a labor-saving solution.
Thanks for your tips and help,
mapsy
Kalle Kannisto
Re: Fire Cannon (particle) shots that don't move when the emitter moves
on Apr 5, 2016 at 7:52:17 am
Keyframe the emitter position.
