Trapcode Particular - Custom Particle Opacity
Thali Ferreira
on Apr 4, 2016 at 7:07:22 pm
Hello there!
I am starting to learn AE and particles in general and I was doing some exercises with trapcode particular. I created a leaf as custom particle and made it grow on a branch, but some particles have the opacity low after they finished growing even though all the opacity settings are on 100%. Do you guys know why? I am using Sprite as a particle type. Here is the link for the picture:
http://www.trapcode.com/storage/upload/customparticle.jpg
Kalle Kannisto
Re: Trapcode Particular - Custom Particle Opacity
on Apr 4, 2016 at 8:52:49 pm
Are you using a Layer as the Emitter? If you hit a semi-transparent pixel, you'll get semi-transparent particles. If so, you can fix that by using curves adjustment on the alpha channel of the layer (precomp it so it reads the curves adjustment).
Thali Ferreira
on Apr 4, 2016 at 9:07:48 pm
Makes sense!yeah, I am using the branch layer as emitter, which layer should I do the adjustment on? The particle or emitter layer?
Chris Keller
on Apr 4, 2016 at 11:30:56 pm
do it on the layer you are using as your emitter, in this case the branch.
