AE won't open a project. ID layer error
Mateo Mazzini
on Apr 4, 2016 at 3:26:50 pm
I have to move one project from one iMac to a macbook pro... both have after effects cc 2015, and I believe the same plugins. it is a motion graphics project plenty of shape layers, which are combined with puppet tools and stuff like that. when i open the project in the macbook pro, before it finishes loading the project, this error pops up.
I have been going back and forth with the two machines... saving it for previous versions won´t work either.
Anyone know any work around?
thank you!
Matz
Dave LaRonde
Re: AE won't open a project. ID layer error
on Apr 4, 2016 at 3:33:31 pm
Did you run the Collect Files command before moving the project? To make double-dog sure you would have all the files you needed?
If you didn't, try it and see what happens.
Dave LaRonde
Promotion Producer
Mateo Mazzini
on Apr 4, 2016 at 4:18:29 pm
tried both to collect files and copy the entire project structure.. but neither seemed to work. Finally I tried checking all the layers one by one... and I realised that one plugin were used.. from boris continuum complete 8 suite. which is installed in both machines... but don´t know why.. it made the project file unusable in other machines.
thank you!
Matz
buluce yu
on Aug 20, 2018 at 2:50:42 am
I had the same problems ! If you solved it,will you let me know?
Thank you!!!
