How to make those news shiny edges?
Thanh Le
on Apr 2, 2016 at 5:00:56 pm
I have seen the programes introduce on our national channel and really want to know how they make those shine (or flare) edge on the boxes?
Dave LaRonde
Re: How to make those news shiny edges?
on Apr 2, 2016 at 5:54:09 pm
I don't know how THEY made theirs -- those are news graphics created in minutes, so they did it using special hardware -- but it's easy to fake in AE using a third-party flare plugin. Which one? No clue.
Dave LaRonde
Promotion Producer
jay mueller
on Apr 3, 2016 at 2:04:41 pm
Try optical flares by video copilot
Tudor "Ted" Jelescu
on Apr 4, 2016 at 11:36:18 am
A easy and fast way of creating the effect you're after is if you use CC Light Sweep on a graphic element. So if you design the tabs either separate in AI or using masks on a solid in AE, you can apply Generate/CC Light Sweep and then play with the Width of the sweep, the Edge Thickness and Intensity and you can animate the highlight by animating the center position. You can have the actual sweep be visible or you can turn the Sweep Intensity down to have just the edge appear.
Tudor "Ted" Jelescu
Senior VFX Artist
Thanh Le
on Apr 4, 2016 at 2:15:27 pm
Thanks Ted, I think i figured out how to make it using Optical Flare and CC Light Sweep. The result is briliant. Here is it:
Thanks guys!
