Global frame rate change for entire project?
Steven J Casey
on Apr 2, 2016 at 6:12:19 am
I'm working on a project with tons of comps. Is there a global command to change the frame rate instead of going into every comp manually? This would be a huge time saver, I just don't see where to do it.
thanks,
steven
Pierpaolo Ferlaino
Re: Global frame rate change for entire project?
on Apr 2, 2016 at 8:58:59 am
You can use rd comp setter to batch change composition settings...
Steven J Casey
on Apr 2, 2016 at 4:42:10 pm
Thanks for the quick reply. I tried the script and unfortunately it doesn't seem to work. When applied, AE seems to run for a few seconds then goes into "not responding" mode and is locked up. Any other options?
Pierpaolo Ferlaino
on Apr 2, 2016 at 11:10:00 pm
I use this script on large projects with no problem... However I'm still on CC2014... Unfortunately I don't know other methods to batch change frame rates for after effects compositions... Maybe someone else can help....
