Advanced Lightning Circle
Oliver Harrison
on Mar 27, 2016 at 3:38:40 am
I have an animation i'm trying to replicate, but I've encountered some issues in the advanced lightning. I am trying to simply get a ball with lightning streaming randomly from different points on the circumference of the circle. Here is the picture:
I think it is "anywhere" lightning, but I can't figure out how to get it to branch with segments equal in width, and completely randomly. How would I animate it to get the interior lightning to move?
Kalle Kannisto
Re: Advanced Lightning Circle
on Mar 27, 2016 at 7:53:34 am
Make a circular mask on a solid, set it to subtract, and precomp the layer, then add the effect. Use alpha barrier at 100% to make the lightning stay inside the circle. You can wiggle the start point to get it to animate.
Oliver Harrison
on Mar 27, 2016 at 1:38:53 pm
Do I use the anywhere strike setting? Because then the problem is that it originates from the center, as opposed to the circumference of the circle.
Kalle Kannisto
on Mar 28, 2016 at 9:37:49 am
It will originate from the origin point, so put the origin point somewhere near the edge.
Oliver Harrison
on Mar 28, 2016 at 9:07:50 pm
Worked like a charm! Many thanks!
