Keying Transparent Fabrics?
Shaun Barnett
on Mar 24, 2016 at 6:28:22 pm
I'm working on a project with a character in a sheer (gauzy) outfit on a green screen. Are we nuts or is this possible? I know it's not ideal and I'm pushing for tests before the shoot.
Dave LaRonde
Re: Keying Transparent Fabrics?
on Mar 24, 2016 at 9:20:22 pm
It IS possible, but keep this stuff in mind:
  • You need a VERY well-lit subject & background, keeping in mind that Keylight likes its chroma key backgrounds a bit on the dark side
  • You need good images -- don't expect success from a DSLR or HDV, going with the highest-quality acquisition codec you can use
  • You may have to mask & key the sheer fabric separately from the rest of the subject
  • You are oh-so-extremely wise to shoot test video to overcome the trouble spots before you shoot for real
Dave LaRonde
Promotion Producer
Kevin Camp
on Mar 24, 2016 at 9:54:00 pm
Andrew Devis has a tutorial series for multi-later keying that covers keying shear fabrics that may help you out.
https://library.creativecow.net/devis_andrew/Multi-Layer-Editing-1/1
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Lisa Tanner
on Mar 24, 2016 at 10:00:09 pm
Hey, I've worked with that footage, but didn't know it was part of a tutorial. Thanks!
Lisa Tanner
on Mar 24, 2016 at 10:01:57 pm
Gotcha. Thanks so much for the tips. Will "well lit subject" still let us match the lighting of the location plates? I'm asking them to light the green screen separately for flatness.
Kevin Camp
on Mar 24, 2016 at 10:36:37 pm
the screen will definitely be lit separately from the subject.
as for the lighting of the subject, your key light should reflect any obvious lighting in the plate, but after keying, you will likely need to make adjustments to the subject while you are compositing it with the plate.
here's an older written tutorial, but you can find newer video tutorials out there:
https://library.creativecow.net/articles/coots_brendan/greenscreen.php
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Lisa Tanner
on Mar 25, 2016 at 6:20:15 am
Gotcha. Thanks!
