create tech eye with trapcode
Susan Lan
on Mar 22, 2016 at 7:12:39 pm
Hi, I have a real footage of a blinking eye, I want to turn that blinking eye into a tech eye like this one,
can that be achieve with trapcode particular in AE?
Dave LaRonde
Re: create tech eye with trapcode
on Mar 22, 2016 at 8:19:46 pm
That clip appears to have been done in a 3D application and not AE. AE might have come into the equation to create this by rendering the final composite of a number of passes from the 3D application.
Dave LaRonde
Promotion Producer
Michael Szalapski
on Mar 22, 2016 at 9:18:47 pm
I'd be more inclined to try to make it in Form vs. Particular, but it'd be even better if you could do it with a 3d model of an eye.
- The Great Szalam
Daniel Waldron
on Mar 22, 2016 at 9:35:39 pm
In addition to the 3D movement on the eye and a particle system of some sort, I see a lot of animated shape layers, Plexus or Nodes 2, animated text, grids, and a healthy does of blurs or depth of field. A shot of this complexity can't be created with a single plugin or effect.
Susan Lan
on Mar 23, 2016 at 7:25:18 pm
Thanks! then I must first create a eye blinking animation, ┬┐do you know any tutorial about creating and animating a blink eye please? then I must import de 3d sequence into AE with trapcode form?
