how to make this effect?
Jay Neglia
on Mar 21, 2016 at 4:15:22 am
hi i was wondering if anyone had an idea on how to make the wavy stuff like in this video? i have the trapcode suite if that helps :)
https://sendvid.com/cw11b2mn
thank you so much!
Kalle Kannisto
Re: how to make this effect?
on Mar 21, 2016 at 7:31:10 am
That is a refraction effect. I don't remember if you can do that in pure AE, but perhaps the glass effect does refraction.
The original image might be as simple as a couple of circles or a wiggled path, and the whole thing is put through a refraction effect -- as if seen through a piece of mottled glass -- at varying smoothness settings.
John Cuevas
on Mar 21, 2016 at 1:57:47 pm
I think a combination of fractal noise & find edges should get you most of the way there.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Chris Evans
on Mar 21, 2016 at 2:19:13 pm
Draw some shapes, throw Turbulent Displace on it, increase the amount to around 1000, play with settings.
