How do I make a background animations last longer than 5 sec?
Jannes Lukas
on Mar 19, 2016 at 9:27:23 pm
I have a solid layer. On top of that I added a background animation from the animation preset's menu, but the animation only lasts the first 5 seconds of my comp, then it stops and just stays frozen. How do I make the animation run throughout my entire comp, which is 40 sec in this case?
Michael Szalapski
Re: How do I make a background animations last longer than 5 sec?
on Mar 19, 2016 at 9:41:54 pm
Select the layer and press U to reveal properties with keyframes. You'll notice that the last keyframes are all at about five seconds. You could move them to the end of your comp, but then the animation will likely be too slow. You'll need to change the value of the keyframes to maintain the speed.
Alternatively, use an expression to make the values keep changing
loopOut(type="continue")
- The Great Szalam
Jannes Lukas
on Mar 20, 2016 at 4:26:40 pm
Thanks a lot!! :)
Michael Szalapski
on Mar 21, 2016 at 2:09:09 am
You're welcome! :)
- The Great Szalam
