Light glow on text from left to right
Lucy Lu
on Mar 16, 2016 at 8:06:21 am
Hi! I’ve been working a lot with Premiere, but I’ve recently started playing around in After effects as well. I’ve been working on a project, but there was one thing i couldn’t figure out how to do. I tried google searching but i didn't find anything helpful. I’m wondering how they did, or rather how i can achieve a similar effect on the text as they’ve done in this trailer:
As i’ve said i’m not really that experienced with this program, so i’d appreciate if you’d explain in a way that I could understand! Thanks for the help!
(Sorry if I posted this in the wrong forum)
John Cuevas
Re: Light glow on text from left to right
on Mar 16, 2016 at 1:33:32 pm
Make your text layer. Add an adjustment layer above it and add the glow effect, tweak the settings to taste. Now just add a mask to the adjustment layer(about 25% the width of the comp), twirl open the settings and add a very large horizontal feather. Now just animate the mask from left to right.
Here's an example project demonstrating technique.
9890_glowtext.aep.zip
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Michael Szalapski
on Mar 16, 2016 at 4:32:17 pm
Or CC Light Sweep (or whatever it's called).
- The Great Szalam
Lucy Lu
on Mar 18, 2016 at 12:45:52 pm
Hi again. I want to thank you both for taking your time to answer my question, it really helped me out! I'm very thankful, and I appreciate the quick response. Thanks.
Michael Szalapski
on Mar 18, 2016 at 5:45:14 pm
No problem! :)
- The Great Szalam
