Will a Project imported into another Project Update changes?
Fred Matthews
on Mar 14, 2016 at 6:38:39 pm
I have a lot of small Projects that I use in numerous larger Projects and from time to time I make adjustments for various reasons.
Is there any way to have that Project update in the Projects that it has been imported into? Or do I have to delete and re-import it any time that I make a change?
Fred
Dave LaRonde
Re: Will a Project imported into another Project Update changes?
on Mar 14, 2016 at 8:04:01 pm
Sorry, but you have to delete & re-import. Once a project is imported into another one, it's cut off from any changes other than those you make in the current project.
Dave LaRonde
Promotion Producer
Fred Matthews
on Mar 14, 2016 at 8:08:53 pm
That's what I figured you were going to say. When I re-import it should the bigger project recognize it and just replace the old with the new or is that again something that I will have to do manually?
I think I know the answer but I just want to be sure that there isn't a setting somewhere that I can change to take care of these issues.
Thanks, Fred
Dave LaRonde
on Mar 14, 2016 at 9:00:48 pm
See Walter's response below. He works with scripts. It's not Kosher to use them at my workplace.
Dave LaRonde
Promotion Producer
Walter Soyka
on Mar 14, 2016 at 8:33:36 pm
You can try this:
http://aescripts.com/project-sync/
Walter Soyka
