Camera Tracking & Placing an object to use the track data
Doug Depker
on Mar 14, 2016 at 8:14:05 am
So I am very familiar with using the Camera Tracker feature in AE to create tracked titles. Now I have a picture that I would like to place in my clip that will use the Camera Tracking data, like the tracked titles, to move across the screen with the scenery. I know to track a title you have to select a number of track points, right click, and choose create title. How do I use the track points to track a picture layer or object?
Thank you.
Walter Soyka
Re: Camera Tracking & Placing an object to use the track data
on Mar 14, 2016 at 9:59:01 am
[Doug Depker] "I know to track a title you have to select a number of track points, right click, and choose create title. How do I use the track points to track a picture layer or object?"
Select a number of track points, right-click, and choose Create 3D Null. Make this new null the parent of your picture layer. If you hold shift while using the parenting pickwhip, Ae will also move the child layer to the same position as the parent layer.
Walter Soyka
Doug Depker
on Mar 14, 2016 at 10:34:53 am
Awesome, exactly what I be needin, arrrrrghhh.
Appreciate thee help me hardy.
Doug Depker
on Mar 14, 2016 at 12:50:30 pm
Hmmmm, i did what you said with the shift and pickwhip, but the layer isn't moving with the null layer...
Walter Soyka
on Mar 15, 2016 at 11:08:37 am
[Doug Depker] "Hmmmm, i did what you said with the shift and pickwhip, but the layer isn't moving with the null layer..."
Is the child layer 3D? If it's not 3D, it will not respond to the camera's motion.
Walter Soyka
Claude Rozsa
on Mar 14, 2016 at 1:47:31 pm
Good morning Walter;
My problem looks a bit similar I think and for some reason I can't have the bench ont the clip to stay put by the lighted pillar on the right wall in the background. I used the same technique creating the 3D null for a torch on the upper right wall foreground and the brazier on the floor being just near the place I want my bench set and it worked perfectly. I can't understand where I'm faulty.May you have a clue...
Thanks in advance
Claude
ps: see attached link to my clip https://vimeo.com/158886057/bcabdd5ca7
Walter Soyka
on Mar 15, 2016 at 11:11:03 am
You shared the result -- can you show us what you're doing, too?
Walter Soyka
Claude Rozsa
on Mar 16, 2016 at 5:26:45 am
I've used the method explained in this tutorial:
https://www.youtube.com/watch?v=xiemS_DLKF4
My problem I think is that I cant really find a track point on the floor near the pillar with 3D camera tracker. Most of the active ones are against and parallel to the wall.
I'm trying now to solve the problem using Mocha Plus. I have not checked yet but I wonder if the option "Camera solve" in Mocha would not be the solution by creating a null object via Moka and on the other hand a Group null with Element 3D and link the group to the Moka Null.The obj is my bench. The clip is the corridor of the amphitheater.
What do you think?
Claude Rozsa
on Mar 16, 2016 at 5:35:06 am
Further info this is the tutorial I found for the possible solution of my problem. Unfortunately the guy did not upload part 2 of his tutorial! Very clever! But I suppose with the first part I'll the essential of his method:
https://www.youtube.com/watch?v=_bMENYVPvTE
I'll keep you posted with my results positive or negative...
Claude
