How to animate points on a line?
Etienne Greeff
on Mar 13, 2016 at 8:38:11 pm
So, I used the Pen tool to draw a Line, and ended up with a 3 point line (1 at each end and 1 in the middle). How would one animate it so that at different times the points are in different locations? The main problem is I am unsure on what property of the line I should put Keyframes on.
I thought this would be something obvious, but I couldn't seem to find it everywhere.
Kalle Kannisto
Re: How to animate points on a line?
on Mar 14, 2016 at 7:57:07 am
Twirl open the "Path" item and you will see the stopwatch there.
Etienne Greeff
on Mar 14, 2016 at 10:06:44 am
Ah, can't believe I missed that. Thanks!
